PROBLEM
The Create Map Tile Package tool in ArcGIS Pro does not recognize services for tiling schemes
First Published: December 9, 2016
In ArcGIS Pro, when browsing and selecting a valid map service to use for the tiling scheme of the Create Map Tile Package tool output, the Service field displays the red X icon, indicating that the service selected is not valid.
The Services field in The Create Map Tile Package tool
Additionally, when browsing to the folder containing an XML tiling scheme file to add as the service input, the XML file does not appear in the browse window.
Cause
This is a known issue (BUG-000085075). This issue occurs when clicking the Browse icon Browse icon to add a service or an XML tiling scheme file as the input in the Service field of the Create Map Tile Package tool.
Solution or Workaround
Do not add a map service directly to the Service field. Instead, use an XML file as the service input. Since the issue occurs when browsing to add the service, avoid using the Browse icon Browse icon when adding the XML file.
As a workaround, copy the file location of the XML file from Windows Explorer, and paste it in the Service field of the Create Map Tile Package tool. Ensure that the .xml extension is included at the end of the XML file name.
Alternatively, drag and drop the XML file from Windows Explorer to the Service field.
Article ID: 000014360
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
