PROBLEM
The Convert button is missing for ArcGIS Pro extensions when converting Named User licenses
When converting Named User licenses to Concurrent Use licenses or Single Use licenses in MyEsri, the option to convert extensions is missing.
Cause
The core product licenses of the extensions are not converted. Extensions must only be converted after the core product licenses are converted. For example, before converting ArcGIS Pro extension licenses such as the ArcGIS 3D Analyst extension, convert the licenses for ArcGIS Pro first.
Solution or Workaround
Convert the core product licenses of the Named User licenses, as described in ArcGIS Pro: Convert Named User licenses to Single Use or ArcGIS Pro: Convert Named User licenses to Concurrent Use .
Once the authorization numbers are generated, the convert option for the extensions becomes available.
Article ID: 000018633
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
