PROBLEM
The color of a raster dataset in ArcGIS Pro is different from the original image
First Published: June 17, 2021
Last Published: June 17, 2021
When adding a raster dataset to an ArcGIS Pro map, the original color of the raster image is not preserved. The images below show the original image in Windows Photo Viewer and the raster dataset added in ArcGIS Pro.
The image in Windows Photo Viewer.
The original image displayed in Windows Photo Viewer.
The raster dataset in ArcGIS Pro.
The raster dataset displayed in ArcGIS Pro where the colour is different from the original image.
Cause
ArcGIS Pro renders the raster dataset with the default stretch type symbology before the map is displayed in the map view. The Stretch function enhances the image by changing its properties, such as brightness, contrast, and gamma, through multiple stretch types.
Solution or Workaround
Use one of the methods below to display the added raster image with the same specifications as the original image.
Set Stretch type to None in the Symbology pane
  1. Open the ArcGIS Pro project.
  2. In the Contents pane, right-click the raster layer, and select Symbology.
The Contents pane with the raster layer to select the symbology from the list.
  1. In the Symbology pane, on the Primary symbology tab, select None from the Stretch type drop-down list. Refer to ArcGIS Pro: Learn more about the stretch types for more information.
The Primary symbology tab displaying the properties of the symbology for the raster layer.
Set Stretch type to None in the Options window
Use this workflow when there are more than one raster datasets. This method removes the stretch type for all the raster datasets by default before adding them to the map.
  2. In the Contents pane, right-click the raster layer and select Remove to remove the raster layer.
The Contents pane with the raster layer and remove is selected to remove the raster layer from the map.
  1. Click the Project tab on the ribbon to open the settings page.
The ribbon with the two main tabs,Project and Map.
  1. On the settings page, click the Options tab on the left to open the Options window.
The settings page with the list on the left of the page for the project options
  1. In the Options window, under Application, click Raster and Imagery.
  2. Under Set options for working with rasters and imagery, expand the Appearance node, and expand the Custom rendering defaults node.
  3. Check the Enable custom rendering defaults checkbox.
  4. Select None from the Stretch type drop-down list.
  5. Click OK.
The Options window with the list of applications such as general, map and scene, editing, raster and imagery and geoprocessing.
  1. In the Catalog pane, browse to and right-click the raster dataset. Select Add To Current Map to add the raster dataset to the map.
The raster dataset in Folders in the Catalog pane
Set Source Type to Processed in the Raster Dataset Properties window
The Contents pane with the raster layer.
  1. In the Catalog pane, click Folders and browse to the raster dataset.
  2. Right-click the raster dataset in the folder and select Properties.
  1. In the Raster Dataset Properties window, on the General tab, expand the Raster Information node.
  2. Select Processed from the Source Type drop-down list. Refer to ArcGIS Pro: General properties for more information.
  3. Click OK.
The expanded Raster Information node with the  properties of information display
  1. In the Catalog pane, browse to and right-click the raster dataset. Select Add To Current Map to add the raster dataset to the map view.
The image below shows the color of the added raster dataset in the ArcGIS Pro map view matches the original image.
The raster dataset displayed in the ArcGIS Pro map view in the original colors.
Article ID: 000025600
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
