PROBLEM
The Clip tool generates empty output in ArcGIS Pro
Last Published: October 13, 2021
In ArcGIS Pro, running the Clip tool generates an empty output, and returns the following warning message:
Warning:
WARNING 000117: Warning empty output generated
Empty output generated by the Clip tool
Cause
  • The layer contains broken geometry.
  • The desired point layer falls outside of the polygon layer when clipping the layers.
Point layer falls outside of the polygon layer
Solution or Workaround
Depending on the cause, use either one of the following solutions:
Repair broken geometry before using the Clip tool
  1. In ArcGIS Pro, navigate to View > Geoprocessing.
Navigate to Geoprocessing
  1. In the Geoprocessing pane, search for the Repair Geometry tool in the search box.
Search for the Repair Geometry tool
  1. Specify the geometry layer for Input Features. Click Run.
Select geometry for Input Features
Ensure the geometry layer overlaps one another
To circumvent the error, ensure the features in the desired layers overlap one another. The following image shows an example of the overlapped features from different layers.
Sample of overlapping layers
Article ID: 000026480
Software:
  • ArcGIS Pro 2 8 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
