PROBLEM
The Change Version option is not available in ArcGIS Pro
Last Published: April 28, 2022
In ArcGIS Pro, the Change Version option is not available after right-clicking the data source from the Contents pane.
The image below shows the Change Version not available in ArcGIS Pro.
The Contents pane with the Change Version not available.
Cause
  • The data source is not an enterprise geodatabase.
  • The dataset is not registered as branch versioned.
Solution or Workaround
Use one of the methods below to resolve the issue.
Connect to an enterprise geodatabase
In ArcGIS Pro, set up a connection to an enterprise geodatabase. Refer to ArcGIS Pro: Set up a database connection for instructions.
Alternatively, use the Create Enterprise Geodatabase or Enable Enterprise Geodatabase tools to create a new enterprise geodatabase.
Register the dataset as branch versioned
In ArcGIS Pro, register the dataset as branch versioned instead of traditional versioned. Refer to ArcGIS Pro: Register a dataset as branch versioned for instructions.
Use the Change Version geoprocessing tool
In ArcGIS Pro, use the Change Version geoprocessing tool instead of right-clicking the data source from the Contents pane to change the version. Refer to ArcGIS Pro: Change Version (Data Management) for instructions and information.
Article ID: 000027591
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
