PROBLEM
If the DynamicValue table is changed within a map document (MXD), the Attribute Assistant does not automatically update to reflect the new table as the active DynamicValue table.
When the Attribute Assistant is turned on while using the Attribute Assistant toolbar, a snapshot is taken of the current DynamicValue table within the Table of Contents. As long as the Attribute Assistant is turned on, the DynamicValue table can be removed from the Table of Contents. The Attribute Assistant continues to function normally, operating off of the snapshot from the original DynamicValue table.
Article ID:000011971
Get help from ArcGIS experts
Download the Esri Support App
