PROBLEM
The ArcGIS Online option is not displayed when adding layers to a web map
Last Published: June 23, 2020
In ArcGIS Online, layers can be added to a web map. These layers can be searched from within the organization, Living Atlas, ArcGIS Online, and so on. However, in some instances, ArcGIS Online is not displayed as an option when adding a layer to a web map, as shown in the image below.
Image showing ArcGIS Online is not an option when adding layers to a web map in ArcGIS Online.
Cause
The security setting set by the administrator limits members from searching for content outside the organization. Refer to ArcGIS Online: Configure security settings for more information.
Solution or Workaround
Follow the steps below to enable members to search for ArcGIS Online layers.
  1. Log in to ArcGIS Online with administrator privileges.
  2. Click Organization. Click the Settings tab.
Image showing the Settings tab under the Organization tab.
  1. Click Security on the left side of the page, and navigate to the Policies section. Enable the Members can search for content outside the organization option.
Image showing the Policies section
Article ID: 000023365
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
