PROBLEM
The ArcGIS Dashboards serial chart category does not display labels for all data
Last Published: December 22, 2022
In ArcGIS Dashboards, a serial chart displays a series of data points along a horizontal (x) and a vertical (y) axis. However, in some instances, the serial chart category does not display the labels for all data. For example, the image below shows the number of homicides in each city in the US, but the labels for some cities are not displayed in the chart.
The image of the labels for some cities are not displayed in the chart.
Cause
The issue occurs when there is insufficient space to display all the labels.
Solution or Workaround
Change the orientation of the axes
  1. Navigate to the ArcGIS Dashboards page. Select the desired dashboard, and click the Edit icon.
The image of the Edit icon being highlighted in ArcGIS Dashboards.
  1. In the Serial chart element, click the Configure button.
  2. In the Serial chart window, click Chart.
  3. Under Chart options, select the required orientation for Orientation. Click Done and save the dashboard.
The image of the Orientation section being highlighted for selection in the 'Serial chart' window.
Enable the Scrollbar function
  1. In the Serial chart element in ArcGIS Dashboards, click the Configure button.
  2. In the Serial chart window, click Category axis.
  3. Under Category axis, expand Settings if needed. Toggle Scrollbar on.
  4. Click Done and save the dashboard. Slide the scrollbar to display the desired data.
The image of the Scrollbar option is being toggled on under Category axis.
The image of the scrollbar function being enabled in the dashboard.
Edit the size of the titles
  3. Under Category axis, expand Settings if needed. Edit the value in the Title size (px) box.
The image of the size of the title for Category axis to be edited.
  1. Repeat Steps 2 through 3 for Value axis. Click Done and save the dashboard.
Edit the size of the labels
  3. Under Category axis, expand Labels. Edit the value in the Size (px) box.
Alternatively, change the label placement type in Placement for Category axis.
The image of the size and placement of the labels for Category axis to be edited.
Reduce the zoom level of the web browser
Reduce the zoom level of the web browser to provide sufficient space for the dashboard.
The image below shows all the labels displayed in the dashboard when the browser is zoomed out to 50%.
The image of all labels being displayed in the dashboard when the browser is zoomed out to 50%.
Article ID: 000028953
Software:
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
