PROBLEM
The Arcade option is not available for a hosted feature layer in ArcGIS Online
Last Published: April 28, 2021
In ArcGIS Online, the Arcade option is not available when calculating field values in a hosted feature layer.
Pop-up of Calculate Field in ArcGIS Online
Cause
This is expected behaviour. In ArcGIS Online, if the hosted feature layer has enabled synchronization or editor tracking, the Arcade option is not available for calculating field values.
Solution or Workaround
Disable the feature layer synchronization to use the Arcade option. To do this, navigate to the item details page of the hosted feature layer, click the Settings tab, scroll to the Feature Layer (hosted) section, and uncheck the Enable Sync (required for offline use and collaboration) option. Click Save to save the edited settings.
Hosted Feature Layer settings in ArcGIS Online
Article ID: 000025471
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
