PROBLEM
The Analyze and Publish options are disabled when sharing layers from ArcGIS Pro to Portal for ArcGIS
First Published: October 4, 2023
Last Published: May 29, 2024
In ArcGIS Pro, when attempting to share layers to Portal for ArcGIS, the Analyze and Publish options are disabled as shown in the image below. In some instances, the Analyze and Publish options are disabled only when selecting Feature, Tile, and Vector Tile under 'Copy all data' in the Share As Web Layer pane.
Examples of URLs in the Edit Portal dialog box.
Cause
  • ArcGIS Server is not configured as the portal's hosting server.
  • The portal's URL added to ArcGIS Pro is misspelled or does not follow the correct portal URL's format.
  • Incorrect Administration URL is used for the federated ArcGIS Server.
  • The role assigned to the member does not have the privileges to publish layers to Portal for ArcGIS. Refer to Portal for ArcGIS: Member roles for more information.
Solution or Workaround
Configure ArcGIS Server as the portal's hosting server
An ArcGIS Server site configured with a data store must be set as the hosting server for the portal to publish layers from ArcGIS Pro to Portal for ArcGIS. Refer to Portal for ArcGIS: Configure a hosting server for more information.
Replace the portal's URL using the correct URL format
In ArcGIS Pro, in the Edit Portal window, replace the portal's URL using the correct URL format below. Refer to ArcGIS Pro: Remove and edit portal connections for instructions.
https://<webadaptorhost>.<domain>.com/<webadaptorname>
Close and restart ArcGIS Pro after adding the correct portal's URL.
Update the Administration URL in the ArcGIS Portal Directory
  1. Log in to the ArcGIS Portal Directory as an administrator using the following URL:
https://<webadaptorhost>.<domain>.com/<webadaptorname>/sharing/rest
  1. On the Users page, browse to Org ID, and click the organization ID.
Parameters of an organization on the User page.
  1. Scroll to the bottom of the Portal page, under Child Resources, click Servers.
  2. On the Server List page, under Server Id, click the ArcGIS Server site ID.
The ArcGIS Server site ID on the Server List page.
  1. Under Supported Operations, click Update Server.
  2. On the Update Server page, update the Administration URL in the Server Admin URL parameter. Refer to Portal for ArcGIS: ArcGIS Server administrative URLs for more information.
  3. Click Update.
Parameters of a server on the Update Server page.
Change the member's role with the privilege to publish layers
Only an organization's default administrator or a member with administrative privileges can perform the following workflow.
In Portal for ArcGIS, change the member's role to Publisher or Administrator. Refer to Portal for ArcGIS: Change member roles for instructions.
Configure the member's custom role to grant the privileges to publish layers
In Portal for ArcGIS, configure the member’s custom role by enabling the privileges to publish the preferred layers in the Content section under the General privileges settings. Refer to Portal for ArcGIS: Configure member roles for more information and instructions.
General privileges settings of contents in Portal for ArcGIS.
Article ID: 000031246
Software:
  • ArcGIS Pro
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
