PROBLEM
When upgrading Portal for ArcGIS from version 10.8 to 10.8.1 for Windows and Linux using the upgradeportal command line utility, an administrator user account named admin with six randomized digits (for example, admin152566) is created. After the upgrade operation is completed, the created administrator user account remains in the portal's index, and cannot be disabled or deleted by other administrators.
The account is created when using the upgradeportal command line utility to successfully complete the upgrade and post-upgrade operations of Portal for ArcGIS. After the operations are completed, the account is removed from the internal database but remains in the index. This results in the account being visible in the portal.
To remove the created administrator user account, reindex the portal's users index by running the Reindex tool in the Portal Administrator Directory.
Note: The URL for the Portal Administrator Directory is https://<machine>.<domain>:7443/arcgis/portaladmin/
Article ID: 000024088
Get help from ArcGIS experts
Start chatting now
