PROBLEM
The Add Items button is missing from the Content and Items tile when editing an API Key on ArcGIS Developers site
Last Published: June 2, 2021
Items such as hosted feature layers, tile layers, web maps, GeoJSON files, or CSV files can be added to an application programming interface (API) key to generate a permanent access token for granting permission to access private content. The items can be added in the 'Content and items' tile when editing an API key.
Content and Items tile with the Add items button shown in the Edit API Key page.
However, the 'Add items' button is missing and items are unable to be added to the API key.
Content and Items tile without the Add items button in the Edit API Key page.
Cause
This is by design. Only Developer accounts have access to the 'Add items' button on the Content and Items tile in the Edit API Key page. This is because ArcGIS Online accounts do not need to use API keys. A Developer account is not associated with ArcGIS Online and the main target is non-GIS users. Organization account users can access the  developers.arcgis.com site, but the view of the site is different from Developer account users. Some of the features available with the Developer account are not available with the Organization account, and vice-versa, relating to the API keys.
Solution or Workaround
If a user has an ArcGIS Online Organization account, the API keys must not be used because the account is not made to utilize them. Using OAuth2 is also recommended to implement security for accessing the applications available in the account.
To use the API keys, a Developer account is required. Those with a Developer account can use API keys to consume ESRI Location services. Refer to ArcGIS Developers: Location services for more information.
Article ID: 000025434
Software:
  • Apps
  • ArcGIS Runtime SDKs
  • ArcGIS API for JavaScript
  • ArcGIS REST API
  • ArcGIS SOAP API
  • Mobile
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
