PROBLEM
The Add Field option is disabled in ArcGIS Pro
Last Published: January 31, 2022
In ArcGIS Pro, when attempting to add fields in an attribute table, the Add Field option is disabled, as shown in the image below.
The River attribute table in ArcGIS Pro showing the Add Field option disabled.
Cause
  • The feature layer of the attribute table is in an edit session.
  • The table type is non-editable in ArcGIS Pro.
Solution or Workaround
Depending on the cause, choose one of the options below to resolve the issue.
Stop the edit session
In ArcGIS Pro, save or discard edits to stop the edit session. Refer to ArcGIS Pro: Save or discard edits for instructions and more information.
Convert the table to an editable table in ArcGIS Pro
  1. Open the ArcGIS Pro project.
  2. In the Contents pane, right-click the table, click Data > Export Table.
  3. In the Export Table window, configure the Parameters tab.
    1. Select the table from the Input Rows drop-down list.
    2. For Output Location, click Browse…. The Browse icon. and select a geodatabase as the location for the output table.
    3. Specify a name for Output Name.
    4. Click OK.
The Export Table window.
The image below shows the Add Field option enabled in the attribute table.
The ArcGIS Pro window showing the Add Field option in the attribute table enabled.
Article ID: 000027008
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
