PROBLEM
The actions for a category selector of a feature service based on grouped values are not available in ArcGIS Dashboards
First Published: June 27, 2023
Last Published: July 10, 2026
In ArcGIS Dashboards, actions describe changes in a dashboard when users interact with the dashboard’s elements. For example, the flash, pan, and zoom actions are used to interact with a map element.
In some instances, when configuring a category selector of a feature service based on grouped values, the actions to interact with the map element are not available, as shown below.
List of actions on the Actions tab before 11.1.
Cause
This is by design, as mentioned in the ArcGIS Dashboards 11.1 documentation. For more information, refer to ArcGIS Dashboards: What's new. The flash, pan, and zoom actions of a dashboard are only available when grouped value categories are used if the element’s data source references an ArcGIS Online hosted feature layer and only in ArcGIS Enterprise 11.1 and later. These options are not available even when using a hosted feature layer in ArcGIS Enterprise 11.0 and earlier.
Solution or Workaround
Upgrade to ArcGIS Enterprise 11.1 and use ArcGIS Online hosted services
Upgrade to ArcGIS Enterprise 11.1 or later, as the flash, pan, and zoom actions are available in these ArcGIS Enterprise releases. Refer to How To: Upgrade to ArcGIS Enterprise 11.x for instructions. After upgrading, when configuring a category selector for hosted services in ArcGIS Dashboards, ensure that the hosted feature layer used is published in ArcGIS Online. Refer to ArcGIS Online: Publish hosted feature layers for more information.
The actions to interact with the map element are now available, as shown below.
List of actions on the Actions tab at 11.1 and later
Article ID: 000030609
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
