PROBLEM
TextMarkerSymbol acetate layers are not legible for ArcMap Services
When navigating though an ArcMap Service in HTML Viewer, the text of an acetate layer becomes illegible.
Cause
If the ArcMap data frame has a reference scale set, the TextMarkerSymbol acetate layer will scale when navigating through an ArcMap Service. Therefore, the size of the text changes making it illegible.
Solution or Workaround
There is no workaround for this other than removing the reference scale from the ArcMap document and then refreshing the ArcMap Service.
This issue has been fixed in ArcIMS version 4.0.1.
Article ID:000005383
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
