PROBLEM
Text labels in callouts do not honor the word spacing in ArcGIS Pro
First Published: May 20, 2021
Last Published: June 16, 2021
In ArcGIS Pro, at times, text labels do not honor attributes with word spacing when callouts are defined. The image below shows the callouts on the map display with no word spacing.
Attributr table and map comparing the attribute names in the Attribute table with the names displayed in the callouts
Cause
The Word spacing property in the Formatting tab of the text symbol properties is set to 0%. Refer to ArcGIS Pro: Text symbol properties for more information.
Solution or Workaround
Use the workflow below to change the word spacing property of the callouts.
  1. In ArcGIS Pro, in the Contents pane, right-click the layer containing the callouts, and click Labeling Properties....
If the layer contains multiple label classes, select the required label class in the Class drop-down menu of the Label Class pane. Refer to ArcGIS Pro: Use label classes for more information.
  1. In the Label Class pane, click Symbol, and click Formatting, Image of the Formatting Icon in the Label Class pane.
  2. Expand Formatting.
  3. Set Word spacing to 100%.
  4. Click Apply.
The Label Class pane with the word spacing set to 100%
The image below shows the text labels in the callouts honor the word spacing setting.
Text labels in the callouts honor the word spacing setting
Article ID: 000025660
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
