PROBLEM
A story map with text copied from Google Docs does not display when viewed in Preview, after refreshing the page, or after publishing the story map, even though the text is saved in draft.
The image below displays the saved draft of the story map.
The image below shows the text is not displayed in the story map after the draft is published.
Google Docs outputs an invalid HTML, which affects the copying and pasting of text in story maps.
The following workarounds are applicable to display text in a story map.
Article ID: 000027814
Get help from ArcGIS experts
Start chatting now
