PROBLEM
Table of contents does not get refreshed after repairing broken IMS layer connection
This problem is addressed in ArcGIS 8.1 Service Pack 1. See Related Information section to download this pack.
ArcMap does not refresh the Table of Contents after you repair a broken link to an image service (if the content of the image service has changed).
Cause
If the author of the image service removes a sub-layer from the service before you repair the link, the removed sub-layer will still be listed in the table of contents after the link is repaired. This problem persists even if you close the document and open it again.
Solution or Workaround
Remove the image service from the document and add it again.
Article ID:000003768
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
