PROBLEM
Table cells do not retain edits
Changes made to a table cell are not retained.
Cause
Two possible causes:
1) You are using the enter or the tab key to toggle between cells.
2) You are saving your edits while the most-recently updated cell in the attribute table remains highlighted.
Solution or Workaround
  • Use the mouse to toggle between cells.
  • Click outside the most-recently updated cell before you save any edits.
    Note: If neither option works, stop and restart the edit session.
Article ID:000002105
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
