PROBLEM
Tab delimited text file tables do not display correctly in ArcCatalog or ArcMap
When a table for a tab delimited text file is opened in ArcMap or ArcCatalog, the data is not correctly entered into columns.
Cause
ArcMap and ArcCatalog interpret files with a .txt, .csv, or .asc extension as comma delimited by default. Files that have a .tab extension are interpreted as tab delimited by default.
Solution or Workaround
Select an option below.
  • Change the extension on all tab delimited text files to .tab.
    Right-click the file in Windows Explorer and select Rename.
  • Modify the schema.ini. This file determines how to read delimited text files.
    For more information on modifying the schema.ini see Accessing delimited text file data
Article ID: 000002961
Software:
  • ArcMap
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
