PROBLEM
Symbology of a layer does not match along ArcGIS Pro/ArcMap interface
Last Published: July 13, 2022
The symbology applied to a layer does not appear the same between different windows such as (ArcMap) the Table of Contents, the layer's Properties > Symbology tab, the Create Features window, or (ArcGIS Pro) the Contents and Symbology panes.
As an example, the picture below shows how the features appear with custom-colored symbology in the Table of Contents while this is missing in the Create Features window:
Cause
The layer is corrupted.
Solution or Workaround
Duplicate the layer within the workspace using either Export Features or Feature Class to Feature Class tools and re-create the symbology. Do not import the symbology to the layer because it might also present conflicts.
Article ID: 000028025
Software:
  • ArcMap
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
