PROBLEM
Survey responses are not displayed in view-only mode in ArcGIS Survey123
Last Published: April 16, 2024
Web form URL parameters can be used in ArcGIS Survey123 to edit existing records and open surveys in view-only mode using the 'mode=edit' or 'mode=view' parameter. In some instances, when opening a survey response, some responses are not displayed when the survey form is opened in view-only mode while they display as usual when the survey response is opened in edit mode.
This is observed in the images below where the response to the question Age is only displayed in edit mode whereas it is not visible in view-only mode.
The survey in view-only mode.
The survey in edit mode.
Cause
When a survey is shared for viewing, the ArcGIS Survey123 web app uses a unique feature layer view so participants are unable to edit the data. This feature layer view is created only when survey results are shared for viewing. If a new field is added to the hosted feature layer of the survey, but not synced across to the view layer, some information is not updated, preventing some responses from being displayed.
Solution or Workaround
Update the hosted feature layer view and ensure all fields are selected to reflect on the survey. Refer to ArcGIS Online: Edit a hosted feature layer view definition for further instructions.
Article ID: 000032203
Software:
  • ArcGIS Online
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
