PROBLEM
Summary Reports geoprocessing tool fails with Error 080323
Last Published: October 8, 2021
The Summary Reports geoprocessing tool can be run with ArcGIS Online as the data source or with a locally installed Business Analyst dataset. When using ArcGIS Online as the data source, the Summary Reports tool is currently limited to 50 features. If the input Boundary Layer has more than 50 features, the geoprocessing tool fails to run with ERROR 080323:
ERROR 080323: The number of input layer features exceeds the current service limit (50).
ERROR 080323
Solution or Workaround
  • Limit the number of features in the input Boundary Layer to be 50 or less.
  • Run the geoprocessing tool with a selection of 50 or less features in the input Boundary Layer.
  • If you have locally installed Business Analyst data, set it as data source. When a locally installed Business Analyst dataset is set as the data source, there is no limit on the number of features.
Article ID: 000026586
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
