PROBLEM
Starting ArcMap, splash screen appears but application fails to start
ArcMap startup splash screen appears for 2-3 seconds then disappears and application fails to start.
Cause
Printers were changed and a print job was issued during the last ArcMap session.
Solution or Workaround
  1. Find the .mxd file from last session and double click this file. This will start ArcMap.
  2. Select Page Setup from the File menu.
  3. Under Printer Setup, select the name of the default printer from the dropdown list.
  4. Click OK.
  5. Save the Arcmap document.
Article ID:000002134
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
