PROBLEM
Starting ArcMap causes Windows display properties to be reset to 8-bit color
Starting ArcMap causes the Windows display properties to reset from 32-bit to 8-bit color. No other ArcGIS Desktop applications, such as ArcCatalog, cause this problem. When ArcMap is closed, the color is reset back to 32-bit color.
Cause
The total file size of the user profile exceeds 1GB.
Solution or Workaround
Delete all unnecessary files from the user profile, move files not necessarily needing to be stored in the user profile, or create a new user profile.
    Article ID:000010305
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
