PROBLEM
Note: The issue only occurs on virtual machines in the Microsoft Azure Cloud environment.
Your system clock is incorrect. Please set your clock to the current date and time.
Clicking OK on the error message opens the Configure Authorization dialog for Pro because the existing licenses are invalid.
The system clock on the machine is correct. This is not the issue. ArcGIS Pro uses a third-party component called FlexNet Licensing Service. For ArcGIS Pro 3.0.3, we upgraded the license service from version 11.18.2.0 to 11.18.3.0 to address existing bugs and security related issues. Unfortunately, the upgrade included a change in the FlexNet Licensing Service in how it detects and reads the unique machine number (UMN), one of the components used by the trusted storage to identify the machine. The change broke the trusted storage and the existing licenses became invalid as a result.
If you attempt to reauthorize with the same entitlement, the authorization wizard fails with the following warning:
“All requested features have already been authorized on this machine.”
Article ID: 000030617
Get help from ArcGIS experts
Download the Esri Support App
