PROBLEM
Some point cloud data are not visible in ArcGIS Pro scene layer and ArcGIS Online Scene Viewer
In some instances, when viewing a point cloud scene layer in either ArcGIS Pro scene layer or ArcGIS Online Scene Viewer, some point cloud data are not visible.
In ArcGIS Pro scene layer
Some point cloud data are not visible in ArcGIS Pro Scene layer
In ArcGIS Online Scene Viewer
Some point cloud data are not visible in ArcGIS Scene Viewer
Cause
The point cloud data have negative values. By default, point cloud data with negative elevation values are plotted beneath the elevation surface, and are not displayed in the ArcGIS Pro scene layer and ArcGIS Online Scene Viewer.
Solution or Workaround
Use one of the following solutions to resolve this issue depending on the ArcGIS product:
Check the Allow navigation below ground option in the Map Properties dialog box. This allows navigation below ground to view the points beneath the elevation surface. For more information, refer to the following technical article, Problem: The elevation surface in a 3D scene blocks some features.
The following image shows the point cloud data with negative elevation values in the ArcGIS Pro scene layer.
Point cloud data with negative elevation values in the ArcGIS Pro Scene layer
Enable the Underground navigation in the Configure Ground pane. This allows navigation below ground. For more information, refer to the following web help page, ArcGIS Online: Configure ground.
The following image shows the point cloud data with negative elevation values in ArcGIS Online Scene Viewer.
Point cloud data with negative elevation values in ArcGIS Online Scene Viewer
Article ID: 000018921
Software:
  • ArcGIS Pro
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
