PROBLEM
Some of the axis labels are not drawn
When a data frame is rotated, some of the graticule axis labels fail to draw, even though the latitude and longitude lines appear correctly.
Cause
When creating a graticule, ArcMap only places latitude labels on the left and right axes, and only places longitude labels on the top and bottom axes. Rotating the data frame may violate this rule. For example, if the data frame is rotated 90°, latitude labels can't be placed on the top and bottom axes.
Solution or Workaround
Create labels as graphic text in layout view. Use the text tool on the Draw toolbar to do this.
Article ID:000002790
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
