PROBLEM
Some features do not display when zooming in and out of a map in ArcGIS Field Maps
First Published: November 2, 2022
Last Published: November 2, 2022
When zooming in and out of a web map in ArcGIS Field Maps, the features in the map are displayed randomly.
Cause
The visibility range of the feature layer is not maximized and minimized at the zoom level in ArcGIS Online.
The visibility range not set to the maximum and minimum zoom level.
Solution or Workaround
In Map Viewer
  1. Log in to ArcGIS Online and click Content > My Content.
  2. Browse to the web map, click More Options The More Options icon. and select Open in Map Viewer.
  3. On the Contents (dark) toolbar to the left of the page, click Layers The Layers icon..
  4. In the Layers pane, click the feature layer.
  5. On the Settings (light) toolbar to the right of the page, click Properties.
  6. In the Properties pane, under Visible range, set the slider to the maximum and minimum zoom level.
    1. Drag the left handle on the slider to the maximum zoom level.
    2. Drag the right handle on the slider to the minimum zoom level.
The visibility range set to the maximum and minimum zoom level.
  1. On the Contents toolbar, click Save and open The Save and open icon. and select Save.
In Map Viewer Classic
  2. Browse to the web map, click More Options The More Options icon. and select Open in Map Viewer Classic.
  3. In Map Viewer Classic, on the Details tab, click Content and click the More Options The More Options icon. icon below the reference layer.
  4. In the drop-down menu, select Set Visibility Range.
  5. Under Visible Range, set the slider to the maximum and minimum zoom level.
    1. Drag the left scale range to the maximum level.
    2. Drag the right scale range to the minimum level.
The scale range under Visible Range is set to the maximum and minimum level.
  1. Click Save The Save icon. and select Save.
The features are now displayed at all zoom levels in ArcGIS Field Maps.
The polygons displayed on the map in ArcGIS Field Maps.
Article ID: 000028562
Software:
  • ArcGIS Online
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
