PROBLEM
Some exports with 8-bit palette may result in a 4-bit image.
When exporting a map from ArcMap and choosing the 8-bit paletted, 256 color option, the resultant export only contains a 4-bit, 16-color color map.
Cause
If there are less than 16 color values in the map, the resultant export contains 16 color values to minimize file size.
Solution or Workaround
This is a known and expected behavior.
Article ID:000008778
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
