PROBLEM
Software programs (such as Office 2000) prompt for the install source
Starting a software program that was installed with Windows Installer Version 1.0, such as Office 2000, returns a prompt for the install source.
Cause
ArcGIS setup uses Windows Installer 1.1. Updating the installer may result in this behavior with previously installed software packages.
Solution or Workaround
Obtain access to the installation source of the application. Once the application opens successfully, access to the installation source is not required.
For Office 2000 applications, install the Office 2000 SR1a (Service Release)
Article ID:000003018
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
