PROBLEM
When doing the map topology tutorial exercise (Exercise 5 of the Editing GIS Features section in the Geodatabase Workbook), the snap tips that are mentioned cannot be seen.
This is due to an error in the tutorial. The snap tip setting is not saved with the map document but rather in the Normal.mxt file, so if you have not previously set up snap tips on your machine, you won't see them when you do the tutorial.
Article ID:000005902
Get help from ArcGIS experts
Download the Esri Support App
