PROBLEM
Slow performance issues in ArcGIS Pro when there is a large number of layout elements
Last Published: February 11, 2021
It is possible to create and add layouts to projects in ArcGIS Pro. In some instances, using a layout with a large number of layout elements results in slow waiting time after each pan or zoom of the layout, which interrupts workflow.
Cause
There are several reasons for this issue. Refer to Problem: Rendering and drawing performance issues in ArcGIS Pro 2.0 and above for more information. Additionally, the following are possible causes related to a large number of layout elements in ArcGIS Pro:
  • The text uses a halo with a complex fill, an outline, or a transparency setting.
  • The symbols are too complex.
  • The map series is enabled.
  • The ArcGIS Pro project is saved on a network drive.
  • ArcGIS Pro is outdated.
Solution or Workaround
Depending on the cause, follow one of the workarounds below to resolve the issue.
To maintain optimal drawing performance when using labels, refer to ArcMap: Labels.
Remove the halo from the text
  1. In ArcGIS Pro, open the layout, and click the element to open the Element pane.
  2. In the Format Text window, click the drop-down list, and select Text.
  3. Click Text Symbol, and click Halo.
  4. Click the Halo symbol drop-down list, and select the No polygon symbol Image showing the No polygon symbol. box .
  5. Click Apply.
Use a preset halo
Change the halo type to a preset.
  1. Follow Steps 1 through 3 from the workaround above.
  2. Click the Halo symbol drop-down list. Under Polygon symbols, select one of the four preset halo options, preferably one without a transparency setting.
 Image showing the preset halos.
  1. Click Apply.
Use a halo with a single, solid color and no outline
Change the halo type to a single, solid color with no outline.
  1. Follow Steps 1 through 3 of the first workaround.
  2. Click the Halo symbol drop-down list, and select Format polygon symbol….
  3. In the second drop-down list, select Solid fill.
 Image showing the Solid fill option for the halo.
  1. On the left of Format Embedded Polygon Symbol, click the Back button.
The Back button.
  1. Click the Color drop-down list, and select a color.
Image showing the Color drop-down list, and how to select a color.
  1. Click the Outline color drop-down list, and select No color.
Image showing the Outline color drop-down list, and how to select no color.
  1. When prompted with There is uncommitted symbol formatting. Do you want to apply it?, click Yes.
  2. Ensure Outline width is set to 0 pt, and click Apply.
Disable the map series
Disable the map series. Refer to ArcGIS Pro: Enable a map series for steps to do this.
Save the project locally
Save the project locally. Refer to ArcGIS Pro: Save a copy of the current project file with a new name and follow the steps provided in the document, but in Step 4, instead of the network drive, select a location on the local drive.
Update ArcGIS Pro
Refer to ArcGIS Pro: Update ArcGIS Pro for more information and steps to update to the latest version.
Article ID: 000024676
Software:
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
