PROBLEM
If the Site Starters do not work, the following are the common problems and resolutions.
The ArcIMS ActiveX Connector is not installed.
If you are running Windows NT 4.0, the Microsoft XML control may not be properly installed.
The value or case of one or more constants in the global.asa file is incorrect.
This install option is only available through the "Custom Installation" procedure.
Article ID:000004667
Get help from ArcGIS experts
Download the Esri Support App
