PROBLEM
When trying to log in (single sign-on) to ArcGIS Enterprise with an Azure Active Directory SAML identity, the following error is returned:
Error:
Sorry, but we’re having trouble signing you in.
AADSTS700016: Application with identifier '<host.company.com.portal>' was not found in the directory '<Company>'. This can happen if the application has not been installed by the administrator of the tenant or consented to by any user in the tenant. You may have sent your authentication request to the wrong tenant.
The problem is due to a mismatch between the Identifier (Entity ID) specified in the Basic SAML Configuration of the enterprise application in Microsoft Entra ID and the Entity ID configured in the SAML/Enterprise login settings of the ArcGIS Enterprise portal.
To resolve the error, ensure the Entity ID in ArcGIS Enterprise matches the Identifier (Entity ID) configured in Microsoft Entra ID (Azure AD).
Article ID: 000029118
Get help from ArcGIS experts
Start chatting now
