PROBLEM
Show MapTips checkbox is grayed out
The check box 'Show MapTips (uses primary display field)' on the Display tab of Layer Properties can be grayed-out for layers whose data source is in shapefile format.
Cause
The shapefile is not spatially indexed.
Solution or Workaround
Follow the steps below:
  1. In ArcMap, remove the layer in which the 'Show MapTips' check box is grayed-out.
  2. Start ArcCatalog.
  3. Locate and right-click on the shapefile. Click Properties.
  4. Click Indexes tab.
  5. Click the Add button.
  6. Click OK or Apply.
  7. Add the shapefile back into ArcMap. The 'Show MapTips' check box is enabled.
Article ID:000008707
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
