PROBLEM
SHADETYPE STIPPLE produces shading with inconsistent sizes
Solution or Workaround
Summary
SHADETYPE STIPPLE produce shading with inconsistent sizes when plotted via any of the graphics translators.
Cause
SHADETYPE STIPPLE requires a SHADESIZE to be specified.
Solution
Stipples are just like every other type of symbol: they require a size to be specified. All symbols will produce inconsistent results between the screen and the plotter if the size is left at the default (zero). To produce symbols which are consistent in size between the screen and the plotter the size needs to be set to a value greater than zero. The command to specify the size of the SHADETYPE STIPPLE symbol is SHADESIZE.
All symbols require the size to be non-zero in order to produce consistent results between the screen and the plotter. This applies to line, marker, shade and text symbols.
Refer to the ArcInfo command references for SHADETYPE, SHADESIZE, TEXSIZE, LINESIZE, and MARKERSIZE.
Article ID:000001375
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
