PROBLEM
Severe server log message with only "AvailableFonts" as the description, associated with the PublishingTools service
First Published: May 18, 2018
Attempts to publish services failed with an error, "Packaging succeeded, but publishing failed", and the server log recorded the following issue, SEVERE: "AvailableFonts". The message is associated along with the System/PublishingTools.GPServer message. The following image is the sample of the log message.
The image of the SEVERE log message.
Cause
The issue indicates the AvailableFonts HTML and XML files that PublishingTools method is attempting to reference are missing from the PublishingTools folder in the working ArcGIS Server machine.
To check if the files are missing, navigate to the following folder in the machine with ArcGIS Server installed:
C:\arcgisserver\directoried\arcgisoutput\System\PublishingTools_GPServer\System_PublishingTools
The folder contains around 30 HTML and XML files, including two AvailableFonts files.
Solution or Workaround
To fix the issue, the AvailableFonts HTML and XML files must be replaced in the ArcGIS Server folder. The folder that contains the files can be copied from another machine with working ArcGIS Server. After the folder is copied, restart the ArcGIS Server Services. To do this, refer to the following web help document, ArcGIS Server: Start and stop services.
Article ID: 000018401
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
