PROBLEM
Setting a selection tolerance has no effect when identifying WMS layer features
ArcMap allows you to set a selection tolerance in the Selection Options dialog. The tolerance is in pixels and affects the Identify tool as well as the Selection tools.
When identifying WMS layer features, setting a selection tolerance has no effect.
** The feature addressed in this article is only available in ArcGIS 9.0 Service Pack 2, which can be downloaded through the link in Related Information, below. **
Cause
ArcMap cannot set a tolerance for WMS services. This is set by the WMS server.
Solution or Workaround
This is a known limitation with no workaround.
    Article ID:000007407
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
