PROBLEM
SML's &SETKEY command does not allow any function key to be set. Another common problem is that &SETKEY does not work if used in a compiled SML.
ANSI.SYS is either not present in the CONFIG.SYS file, or it is not getting
recognized.
Make sure that the following line or its equivalent is present in the CONFIG.SYS file:
Code:
DEVICE=C:\DOS\ANSI.SYS
Code:
&system "&setkey f1 commands &cr
Article ID:000005468
Get help from ArcGIS experts
Download the Esri Support App
