PROBLEM
Services added to web applications load slowly in ArcGIS Web AppBuilder web apps
Last Published: August 5, 2022
In ArGIS Web AppBuilder, services such as feature services and map services can be added to the map via the Add Data widget. However, these services may take a long time to load data in the web app, especially when compared to the loading times of the same services in ArcGIS Online or Portal for ArcGIS Map Viewer.
Cause
This issue occurs in services containing a large amounts of features, and when a sizable amount of users are attempting to access the web app containing the feature service. In these cases, the service in question can be assigned with a higher number of instances, which is useful in pooling a higher amount of system resources, such as physical memory (RAM) and CPU cores towards the service. However, increasing the number of instances to a point where it exceeds the amount of resources available also causes an overall reduction in system performance, thus increasing load times in web apps.
To summarize, the following are reasons why services may take time to load on a map in a web app:
Solution or Workaround
The following are best practices to improve service performance in web apps.
Article ID: 000028148
Software:
  • ArcGIS Web AppBuilder
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
