PROBLEM
Select by location is not selecting polygons created with the auto-complete polygon tool
Some polygons may be created within a larger polygon using the auto-complete polygon tool. Using the Select by Location tool to select features that 'are completely within' the features of a given layer does not select the newly created polygons.
Cause
The newly created polygons share boundaries with the features of the specified layer.
Solution or Workaround
In this case, the correct option for the Select by Location tool is 'are contained by'. Using this option will allow the newly created polygons to be selected as expected.
Article ID:000006819
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
