PROBLEM
Searching for locations on a map in publicly shared surveys prompts for login in ArcGIS Survey123
First Published: May 25, 2023
Last Published: August 23, 2023
In some instances, when searching for locations on a Map question, the Sign In dialog box is displayed in ArcGIS Survey123 even when the survey forms are set as publicly shared.
The Sign In dialog box is displayed in ArcGIS Survey123.
Cause
  • The ArcGIS World Geocoding Service referenced by the survey is not shared publicly.
  • The basemap layer used in the survey is not shared publicly.
Solution or Workaround
Share the ArcGIS World Geocoding Service publicly
Share the ArcGIS World Geocoding Service to Everyone. Refer to Portal for ArcGIS: Share items with everyone for instructions.
The image of the ArcGIS World Geocoding Service being shared publicly.
Using the ArcGIS World Geocoding Service to do batch geocoding consumes ArcGIS Online credits. Refer to Portal for ArcGIS: Configure the organization to geocode addresses for more information.
Share the basemap layer publicly
Share the basemap layer to the public or use a publicly accessible basemap layer. Refer to Portal for ArcGIS: Create and share basemaps for instructions.
Article ID: 000030639
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
  • ArcGIS Survey123
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
