PROBLEM
In ArcGIS Explorer, when searching by layer in web maps, the search results do not display the searched features.
The image below shows the search results of addresses only instead of both of the addresses and features in ArcGIS Explorer.
Select one of the options below to resolve depending on the cause.
Enable the search by layer feature in the web map settings in ArcGIS Online
In ArcGIS Online, check the By Layer check box in the Application Settings section of the web map. Refer to ArcGIS Online: Configure feature search for maps for more information.
Search for the features in the correct search bar
Search for features within the web map instead of the Search bar in the Maps list page in ArcGIS Explorer.
Note: The search results are not displayed if the search key is not tapped after typing the feature in the Search bar.
Article ID: 000024045
Get help from ArcGIS experts
Download the Esri Support App
