PROBLEM
Scrolling through an attribute table in ArcGIS Pro returns a generic error
In ArcGIS Pro, after connecting to the SQL Server database and loading the tables, the attribute tables can be viewed. However, when scrolling through the attribute table, the following error message is returned:
Although a query layer is built from the table, the error still persists.
Cause
The table contains a composite key (two or more columns make up the unique ID). Selecting only one of the columns for the unique ID during the generation of the query layer results in an error when scrolling through the attribute table.
Solution or Workaround
The following options can resolve the issue:
  • Select the required columns that make up the composite key for the unique ID during the generation of the query layer. For more information, refer to: Create a query layer.
  • Export the table to a geodatabase.
Article ID: 000020435
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
