PROBLEM
Script to download items runs successfully but no items are downloaded in ArcGIS Notebook and ArcGIS Notebook Server
Last Published: March 17, 2025
Running a script to download items using the download() function in ArcGIS API for Python through ArcGIS Notebook or ArcGIS Notebook Server completes successfully, but no items are downloaded to the specified folder location within the script. However, the same script successfully downloads the items when run in Jupyter Notebook or a stand-alone script. For a sample script to download items, refer to How To: Back up hosted content by looping through and downloading hosted feature services in FGDB format.
Cause
A local folder location on the machine is specified in the script. ArcGIS Notebook and ArcGIS Notebook Server do not run locally and are not directly connected to the machine's local folder. In contrast, Jupyter Notebook and a stand-alone script run locally and are directly connected to the machine's local folder. As a result, the script runs successfully when a local folder is specified within the script.
Solution or Workaround
Run the script in Jupyter Notebook or as a stand-alone script
Jupyter Notebook is installed with ArcGIS Pro, along with the IDLE Python editor. When using a local folder to download the items from ArcGIS Online or the ArcGIS Enterprise portal, Esri recommends using the Python editor for a direct connection to the machine.
Specify the web folder location and download the item from ArcGIS Notebook and ArcGIS Notebook Server
  1. On a notebook, click the Files tab and click the home folder.
The Files tab on a notebook
  1. Create a new folder using the New folder button. Note the folder location and specify it within the script to download the items. The following is a sample code snippet:
folder_path = r"/arcgis/home/Test"
The web folder location on a notebook
  1. Run the script.
The downloaded items can be accessed and downloaded from the folder.
The downloaded items in the notebook web folder
Article ID: 000035034
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS API for Python 1 x
  • ArcGIS Enterprise 11 1
  • ArcGIS Enterprise 11 3
  • ArcGIS Enterprise 11 2
  • ArcGIS Enterprise 11 4
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
