PROBLEM
Saving edits after moving a node changes the node's attributes
When using the ArcMap Editor's Shared Edit tool to move a coverage node feature, the attribute values on the node may be changed when the edits are saved.
Cause
This is a known issue.
Solution or Workaround
This issue has been resolved in ArcGIS Version 8.1.2.
Article ID:000004298
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
