PROBLEM
SAML single sign-on in ArcGIS Online or the Enterprise portal fails with an error
First Published: October 1, 2024
Last Published: October 2, 2025
When using the Security Assertion Markup Language (SAML) single sign-on in ArcGIS Online or the ArcGIS Enterprise portal, the following error is returned:
Error:
Unable to login using Idp. Error validating encrypted Assertion. Unwrapping failed.
Cause
This error occurs when the Encrypted Assertion setting is disabled in ArcGIS Online or the Enterprise portal, and the token encryption certificates are enabled in Microsoft Entra ID.
Solution or Workaround
ESRI recommends keeping the Encrypted Assertion setting enabled in ArcGIS Online or ArcGIS Enterprise to maintain a stronger cybersecurity posture.
  1. Turn on the Encrypted Assertion setting in ArcGIS Online or the Enterprise portal.
    1. Log in to ArcGIS Online or the Enterprise portal.
    2. Navigate to Organization > Settings > Security > Logins > Configure Logins.
    3. Click Show Advanced Settings.
    4. Enable the Allow Encrypted Assertion setting.
  2. Deactivate the token encryption certificates in Microsoft Entra ID.
    1. Log in to the Microsoft Azure Portal.
    2. Open Microsoft Entra ID.
    3. Navigate to Enterprise Applications.
    4. Open the relevant ArcGIS Online or ArcGIS Enterprise application.
    5. Click Security.
    6. Navigate to Token Encryption.
    7. Deactivate and delete the relevant certificates.
Article ID: 000033809
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
