PROBLEM
The IDW (Spatial Analyst) tool interpolates a raster surface from an input point feature class. In some instances, using a polyline feature class as a barrier when running the IDW tool on the input points in ArcMap or ArcGIS Pro results in a long processing time.
When there are a large number of polyline features and vertices in the polyline feature class used as the barrier in the IDW tool, this significantly extends the processing time.
Simplify or reduce the total number of the barrier features to shorten the IDW tool processing time. The number of records in the polyline feature class attribute table can be reduced by dissolving the polyline features based on a field (such as the name of a site) to group them. To reduce the number of vertices, run the Generalize or Simplify Line tool.
Note: The Generalize tool modifies the input data, while the Simplify Line tool provides more parameters and outputs a new simplified line feature class.
Article ID: 000018818
Get help from ArcGIS experts
Start chatting now
