PROBLEM
Running a script in a Jupyter Notebook cell fails and returns an error in the command prompt
First Published: January 6, 2017
Attempts to run a script in a Jupyter Notebook cell fail with no error returned in the notebook. However, the following error is returned in the command prompt.
Error:
zmq message arrived on closed channel
The image of the zmq error
Cause
By default, Jupyter Notebook uses port 8888. However, the port may be inaccessible due to the machine’s firewall security or if it is used by another application. The port numbers' availability can be checked using Windows Command Prompt. To do so, run the following command:
netstat -na | find "<port number>"
The following image is a sample result of the command.
The image of the netstat command
Solution or Workaround
To resolve this issue, start Jupyter Notebook with a custom port number. Check the availability of the desired port, and run the following command in the Python Command Prompt:
jupyter notebook --port=<port number>
User-added image
Alternatively, the default start port can also be changed. To do so:
  1. Start the Python Command Prompt and run the following command. This command creates a .py file, jupyter_notebook_config.
jupyter notebook --generate-config
  1. Navigate to the following folder location:
C:\Users\<USER>\.jupyter
  1. Edit the jupyter_notebook_config.py file using a text editor, for example, Notepad++ or IDLE.
  2. Find and uncomment the script, c.NotebookApp.port = 8888.
  3. Edit the port number to the desired port number, for example:
c.NotebookApp.port = 8889
Image sample of the jupyter_notebook_config.py file
Article ID: 000015077
Software:
  • ArcGIS API for Python
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
